Hi folks,
Wondering if anyone here has managed a solution to this one..?
The MF-104M can have it's filter 'programmed' with Midi CC85 to be bright even on the long delays.
My question is, if you're taking it out on a gig for example and want to use it live in that mode - and you're not near your sequencer or other means of programming it - what are the other alternatives to setting it..?
MF-104M CC programming...
- stiiiiiiive
Re: MF-104M CC programming...
Hi mate.
Here are some solutions:
- MidiSolutions do a lot of little boxes capable of sending pretty much whatever you need. They could be overkiiled for this, though.
- Clavia MicroModular : cheap, hybrid-SW/HW-modular synth. Its successor, the G2, has MIDI dedicated modules. Not sure if the old Modulars have: to be checked.
- Otherwise, any programmable MIDI controller can do this, starting with the Little Phatty "pot mapping".
Hope this helps
Hope this helps
