LP Polyphony is limited
Everything Phatty.
rachel
Post by rachel » Thu Oct 19, 2006 2:22 am
I have my MLP setup as my main controller now, but I am suspecting
something is up with the polyphony. It seems it is only 3 notes - is this correct?
I thought it should be able to send out at least 8 notes. Is this something
that is known, but can it be adjusted in software somehow?
Yes, I know it is a mono synth, but If I use it in local off mode and then make it
my controller through Logic, I should be able to bang out a big cluster
of MIDI note chords.
rachel
babamoog
Post by babamoog » Thu Oct 19, 2006 6:03 am
The only limit should be the number of keys on the keyboard (37). I can lay my arm on the keyboard and see (using midi-ox) lots of notes go out and stay on, then see them go off when lifting the arm. Is this what you mean?
I'm using firmware version 1.02c.
--baba
beeblenoid
Post by beeblenoid » Thu Oct 19, 2006 7:06 am
I'm using my Phatty as a controller in Logic as well, I can bang out thick jazz chords no problem. It's curious that you're only able to output 3 or so.
I don't use Local Off mode though, I just mute the Phatty when I'm controlling other things with it -- but I doubt that would make a difference.
cheers.
rachel
Post by rachel » Thu Oct 19, 2006 1:48 pm
Thanks for confirming that for me, I think I have a MIDI routing problem.
rachel
Post by rachel » Sat Oct 21, 2006 3:45 pm
It was a MIDI problem. I have 3 USB MIDI devices, one is an AMT (3x chained
together), a BCF2000 and an MX-200 reverb.
The last 2 were sending repeats of everything, making my system go haywire.
I think I have it sorted now... thanks!
rachel
