1) When sending clock out from my M32, the 1st step is received like a quick pulse and throws everything off, effectively, sending 2 clocks on the 1st step. This behavior seems to start after I change a pattern and reset. This doesn't happen when I run a sequence after M32 initial power up.
2) When stopping a sequence then restarting, either the behavior above is observed, or the DFAM just sits for a few clocks (sometimes as many as
FWIW, firmware 2.0.1 and I have Delay Pattern Set turned off and Load Saved Timing also set to off (toggling these doesn't make a difference). Also, it makes no difference on the M32's pattern, it could be the default blank one or any programmed one.
Is this the M32 or is this the DFAM?
