Does the Matriarch Case allow you to keep cables plugged in?
MaxFerency
Post by MaxFerency » Tue Jan 26, 2021 1:16 am
If you have patch cables plugged into the Matriarch, can you put it into the Moog soft case with them still in or will it not fit and/or mess up the input jacks?
Max Ferency | http://maxferency.org
SYSTEM: macOS & Logic X Pro
GEAR: Matriarch, Sub 37, Korg SV-2, DFAM, Mavis, MF Drive, MF Delay, MF Boost, MF Trem, Maschine
VocoVacca
Re: Does the Matriarch Case allow you to keep cables plugged in?
Post by VocoVacca » Tue Jan 26, 2021 1:38 pm
It's possible to mash down the patch cables enough to close the case, but I would not recommend it. The Moog soft case is a snug fit. The flex part of the cables are forced to bend at a sharp 90 degrees at the end of the rigid plugs. So, I'm concerned that the cables could break or—worse—develop intermittent shorts.
Moog One 16, Matriarch, Mother-32, Subharmonicon, DFAM, Mavis, SubPhatty; Nord Wave 2, Nord Drum 3; ASM Hydrasynth; Teenage Engineering POM-400; Yamaha P-140 piano.
MaxFerency
Post by MaxFerency » Tue Jan 26, 2021 4:22 pm
Ok, Thanks. I assumed as such. I wonder if it would be worthwhile to invest in right angle patch cables so you could put it in the case without having to unplug everything.
