Grandmother / Spring Reverb Gone
chrisme
Post by chrisme » Sat Oct 03, 2020 11:03 am
Hello,
i have a Grandmother about half a year, and now it seems the spring reverb isn't working anymore.
It was fine, when i bought it but now it only acts like a high-pass and produces distortion, when I turn the knob.
No reverb! Strange, isn't it?
Another thing I found, that after a longer time powered on the octave changes sometimes to a lower one.
I thought, I didn't press the the change-octave-key-sequence, but I used Arp and Seq.
I will have a look at the second point with the new FW 1.1.1, maybe it's a bug?
Or I'm just fuzzy...
regards,
Chris.
tastenhoch
Re: Grandmother / Spring Reverb Gone
Post by tastenhoch » Wed Oct 07, 2020 1:59 pm
I had the same problem already 2 times.
First I did send it back to the Seller, they checked it, found nothing, tho it worked again when I had it back.
Then after some time, suddenly again the same problem. I did not play it for 2-3 weeks and put it to another place in the room and there it worked again. So it must be really really sensible to frequencies, setup, whatever, I dont get it but it's really annoying and like that not really useable :(
I now use mostly an effect pedal for reverb.
Best wishes from germany
eandsn
Post by eandsn » Sun Nov 01, 2020 1:21 pm
Were you ever able to solve the reverb issue? I started experiencing the same thing days after my warranty expired and I'm trying to explore all possible solutions before sending it in to Moog. I did speak with their service department and they think the pot needs replacing.
murskaborje
Post by murskaborje » Mon Nov 09, 2020 2:30 pm
Hi!
I got today a demo unit that last week tried and everything fine but now at home the spring reverb don’t work. Some kind of distortion and high pass effect it adds (sounds cool but no reverb). Easy fix or back to the store?
Regards,
Magnus
moogy_j
Post by moogy_j » Tue Nov 10, 2020 10:25 am
murskaborje wrote: Mon Nov 09, 2020 2:30 pm Hi!
Regards,
Magnus
Over in the Facebook User group:
https://www.facebook.com/groups/MoogGra ... 5499357321
One person responded that they opened up their GM and found a loose cable and it fixed the issue.
John
FuzzyCat Software - Software tools for musicians - www.fuzzy-cat.com
"Chonky" - free global parameter manager software for the Moog Matriarch and Grandmother - www.fuzzy-cat.com/products
murskaborje
Post by murskaborje » Sat Nov 28, 2020 12:19 pm
Hi!
Thanks for the replay.
I got it back to the store and two days later it was fixed, the spring was stuck.
