How does Moog One allocate voices per synth?
Polyphonic Analog Synthesizer
jonspace
Post by jonspace » Sat May 23, 2020 4:56 pm
How does the Moog One, or the end user, allocate the voices used per synth?
Are all 8 voices available to all 3 synth parts, and then the voices used as the keys/sequencer triggers them?
Are they predetermined by the operating system?
Or does the end-user configure and allocate the number of voices per synth?
till
Re: How does Moog One allocate voices per synth?
Post by till » Sun May 24, 2020 6:42 am
In normal mode you got the three synths stacked. But most of the times you might like to use just one in order to play 8 voice polyphonic. You can set a keyboard range for the up to three synths used to get layers and splits.
If you do nothing about assigning a number of voices for a synth, the 8 voices are allocated by the Moog One dynamically.
And then there is a parameter to assign a certain number of the available voices to the up to three synths.
It is all explained on page #63 of the manual PDF.
