Voyager: Assign Panel Params to Cursor Button?
Athon
Post by Athon » Tue May 05, 2020 12:47 pm
I would like the ability to toggle between presets and panel parameter with a single command. Though panel parameters may be selected via the Edit menu, my ideal solution would not require use of the display. Is it possible to assign this functionality to the cursor button? That is, can I toggle between presets and panel parameters with a single press of a button? If not, perhaps there is another way to accomplish this toggling capability?
RL
Re: Voyager: Assign Panel Params to Cursor Button?
Post by RL » Wed May 06, 2020 5:37 am
you can do this with the 3.6 version.
Here is the description for the download:
http://forum.moogmusic.com/viewtopic.php?f=2&t=22525
In the MASTER menu page 4.4 you can either use the "Recall last Edit" function or
set the "Real Panel Values" for the CURSOR.
http://www.moogmusic.de
ummagumma
Post by ummagumma » Sun May 10, 2020 7:20 pm
+1
this works great, been using it for a while
and Thanks again, Rudi!! much appreciated
