LP and Pro Tools
LP and Pro Tools
Just received mine! I am a brand new Moog user and will be using the LP solely for recording. I have it running directly through my DIGI 002 pro tools system. Wondering if that is sufficient or if i am missing something by not running it through some sort of amp and then into the 002? Any suggestions would be greatly appreciated!
www.animalthug.com
www.myspace.com/planbmusic1
www.myspace.com/jensen40love
Re: LP and Pro Tools
I agree, record it direct.bigboi78 wrote:Just received mine! I am a brand new Moog user and will be using the LP solely for recording. I have it running directly through my DIGI 002 pro tools system. Wondering if that is sufficient or if i am missing something by not running it through some sort of amp and then into the 002? Any suggestions would be greatly appreciated!
You got a good setup there, let me know how it works out(im using a 001 and an Mbox2, and am awaiting the arrival of my first Moog, the LP, as well.)
=-Ben
BrianG is correct - it depends on what kind of sound you're after. I'd suggest trying anythng and everything to get an idea of what the LP sounds like under a variety of conditions. While recording direct will capture the most accurate sound, you may prefer a more colored sound (which can often work better on a track).
To get an idea of what an amp might do to the sound, try a software amp simulator like IK's Amplitube, or use a hardware device like a POD or stompbox. Or use a real amp/mic combo (more work to set up, but remember that thousands of hit records were recorded this way).
- Greg
- Greg
Regardless of the sound you're trying to achieve, it's always best to try and run your Moog through a mic-pre on it's way to your Digi 002. There are a lot of different options out there in an affordable range, but something with tubes will help sustain the warmth of your LP as it gets recorded on to a digital format.
I'll revise my statement. Synths are best recorded directly unless you're looking to color the sound. I run my Voyager through a Twin Reverb sometimes to dirty it up and add some nice spring reverb. Though I'm always afraid the Twin is going to explode...
Recording through an Avalon U5 DI-preamp does noticably fatten up a synth, too. But it is really not required IMHO (especially for a Moog).
Be careful of the levels going into a mic pre, the LP output is line level and the mic pre is looking or mic level.... you could get some really nice distortion
. The Mic pre may or may not have mic line switching, it may or may not have a input level pad on it. You could also use a tube based direct box. Any of the ways will work, part of the fun is trying different things to see what works best for you and for the project you're working on.
Enjoy
Brian
Enjoy
Brian
