Dust Cover
Polyphonic Analog Synthesizer
kk1000
Dust Cover
Post by kk1000 » Thu Apr 11, 2019 11:07 pm
Has anyone else tried out the Moog dust cover from Sweetwater for the One? I am pretty surprised at the results. I mean, it should be simple right? Just put the thing on and you’re protected from dust and critters. Not this dust cover. It actually deposits a layer of small dark fibers iver the entire surface. I vacuumed the inside material well so as to collect the loose stuff but there was no change. So instead of a dust cover I got a dusty cover. It’s going back.
Wow, that’s a tough thing to screw up. It has the Moog logo on it but I don’t know if that means it was made by Moog. Even though it was probably made in China, if the folks at Moog had anything to do with this, they should stick to making synths.
frs
Re: Dust Cover
Post by frs » Sat May 04, 2019 5:22 am
Got my One last wednessday including a One dust cover. Not from Sweetwater, but same issues here in the Netherlands: dark fibers from the dust cover all over the One.
mildwest
Re: Dust Cover
Post by mildwest » Sat May 04, 2019 2:44 pm
Turn it inside out. That’s what I did. It works just as well and solves the problem. No moog logo but who cares. Does the job and keeps the dust off.
starkaudio
Re: Dust Cover
Post by starkaudio » Thu Aug 08, 2019 1:26 pm
Mine had white nickel-to-quarter coin sized spots of white mold (?) or mildew (?) inside it. I wipedit out with a damp cloth. This was yesterday. I'll have to check this afternoon if the black fibers are present after leaving it on overnight.
http://lukestark.com
We could be friends. Hello.
Bobbyjoebob
Re: Dust Cover
Post by Bobbyjoebob » Thu Aug 08, 2019 11:15 pm
I had the same issue with the Sweetwater cover.
I returned it and got this cover: https://www.digitaldeckcovers.com/moog-one (in double-sided quilted black nylon).
Works great.
MWK
Re: Dust Cover
Post by MWK » Mon Aug 12, 2019 9:51 am
Yep, same problem here.
till
Re: Dust Cover
Post by till » Mon Aug 12, 2019 1:16 pm
I got a dust cover from www.viktoryshop.com for my Moog One and several other synths I own.
They are located in Slovenia. So the are EU. So easy to do from Germany.
GEOSynths
Re: Dust Cover
Post by GEOSynths » Thu Sep 12, 2019 5:32 am
Yeah, I've got the one that leaves more dust on the ONE than protects it from...Too late to return, may see about someone Sewing in another layer...£100 for a cover is a bit rich for something that adds MORE dust...
smv
Re: Dust Cover
Post by smv » Thu Sep 17, 2020 5:37 am
I have the same problem too. It is a true shame that a cover that costs more than 100 euros , has this problems . I also tried to wash the interior , but it seems without results
Spacetone
Re: Dust Cover
Post by Spacetone » Tue Sep 22, 2020 12:16 pm
I got my from Studio Slips. Fantastic work, as always. I've purchased many covers from the over the years and they never disappoint. They will customize it any way you want too.
https://studioslips.com
sunny pedaal
Re: Dust Cover
Post by sunny pedaal » Tue Apr 12, 2022 5:22 am
Bought the original one for the moog one:
Worst one i ever got: should be at least 2cm larger on each side
Plus thin
Really not worth the money, so isend it back
Also have original dustcovers for t3 and voyager : much better quality on all levels , wonder why moog took another suplier for these .
HookedOnSonics
Re: Dust Cover
Post by HookedOnSonics » Tue Apr 12, 2022 2:11 pm
I have VoyagerXL, ModelD, MoogOne, and Kronos II all covered by these fine folks:
https://bestampcovers.com/?utm_campaign ... doned_cart
Outstanding Product/Covers, well made, nice soft underlining.
smv
Re: Dust Cover
Post by smv » Thu Apr 14, 2022 2:03 am
I previously purchased the one that has the problem mentioned of these little fiber hairs everywhere.
Totally disappointed.
After i bought one from stardustcovers.com and it is amazing.
Very good looking and no problems at all
benabbiana
Re: Dust Cover
Post by benabbiana » Fri Apr 15, 2022 9:22 am
I bought the standard Thomann dust cover, which is officially a Moog One dustcover as used by Moog, and it's 100% fine. No shedding. Perhaps it was improved at some point.
sunny pedaal
Re: Dust Cover
Post by sunny pedaal » Fri Apr 15, 2022 11:55 am
Didn’t you find it very tight ?
