I think my LFO2 on the Voyager XL may have stopped working correctly for some reason. Whenever I connect the +, - out (or the attenuator 1 with no input) into a destination like VCA volume in, Filter cutoff in, etc, the red LFO2 blinks for a moment, then just goes out. Sometimes it works alright for a few seconds then drops off again. I've tried all the types of output, but the light never works consistently.
For example I set the type to a basic triangle wave (far left setting for the knob) and connect the + LFO 2 out to the VCA volume in. Then I sweep the LFO2 rate knob, sometimes the red light goes on for a little while then it cuts out. The volume follows the red light, so when the red light does start blinking I can hear the note I'm holding down, but most of the time it's just silent. The expected behavior is once the + LFO2 out is connected to a valid input that the light on the LFO2 will blink and behavior similar to the LFO1 red light. Also I've disconnected all other patch cables, midi cables, etc.
I checked a video on youtube and the LFO2 light was pulsing consistently as expected.
I've tried to factory reset and restarting it, but nothing seems to fix it. Does anyone have any ideas of things to try? I really hope I don't need to send it off for repairs.
Thanks a lot for any input!
