Subsequent 37 CV + Mother 32
Everything Sub.
klarrrro
Post by klarrrro » Fri Jul 27, 2018 1:35 am
Hello,
I was wondering if anybody can explain how do I connect the Subsequent 37 CV with Mother 32 / Mother 32 x 2 ?
I was looking for some demos online but could not find any.
Thanks.
kouik
Re: Subsequent 37 CV + Mother 32
Post by kouik » Thu Aug 09, 2018 11:20 am
Hi Klaorrrro,
There is a lot of options out there :
Outputs are on the right of the synth, 4 CV outs (control voltages, can be assigned to many internal functions (pitch, lfo, etc), and 2 gates out (notes trigger, arp step etc)
In order to assign them, the subsequent cv editor (last release, requiring subsequent to be update to version 1.3.2) is really convenient. In the mapping tab, bottom left, you'll see what is assigned to what.
You can also use it from the synth : hold preset for 1 s -> scroll down 10 times -> you'll see the cv out listed there, and you'll be able to assign them a new role
Small example (out of the box if I'm correct)
CVout 1 : KB pitch
CVout 2 : filter EG
CVout 3 : mod 1
CVout 4 : mod 2
gate out 1 : KB gate
gate out 2 : KB gate
So in order to have the KB of the sub playing sound from the mother 32 -> CVout1 to pitch of the mother, and gate out 1 into the gate in of the mother 32.
It may be interesting to get the audio out of the mother 32, into the audio in of the sub, so the sound of the mother32 will be controlled by the FDBK/EXTin pot in the mixer of the sub (it deactivate the internal feedback loop by the way).
Very fat sound should not be a problem then ;)
Then, you'll likely want to connect the mod buses 1 and 2 into the mother32, to control modulation in it too, and be able to use the sub37 lfo to craft sound further.
hope that helped a little bit, enjoy ;)
