The MF108 has internal dipswitches allowing to change output configuration.
Thing is, i want a setup that is not directly explained in the manual:
i would like all settings to be the same as default, but no dry signal, since i'm using a send-return setup.
So, right channel inverted phase wet, left wet.
Is this possible? I know i can just turn the mix dial, but maybe there's a bit of bleed or less noise?
And it's convenient if you would accidentally turn the mix dial in a hurry.
MF 108 output configuration
Sub37,Minitaur,DSIProphet12,Cubase,AbltnLive,Reason,RMEfirefaceUCX +FocusriteOctopreMKIIDynamic, BabyfacePro,LaunchpadPro,AkaiMpk249,ZeroMkII,StrymonBigSky,ShermanFB2, Xbase09,TR808,PF500 Stagepiano, ElCapistan,HeddType07,Mics &Waay too many cables
Re: MF 108 output configuration
Also, there's some kind of firmware update on the moog downloads page. anyone know what it does, and how i can tell if it isn't allready done on my pedal?
