Voyager Distortion Issue
jnastasi
Post by jnastasi » Wed Feb 21, 2018 10:33 pm
I have a Voyager one of the last batch made, that I've owned for almost 2 years. In a smoke free studio, moved only once, in my car. It has been pampered.
I played it in the morning for about an hour and all was fine. I kept in on for about 6 hours and started playing again. The same patch I was playing was getting this distorted pulse. The timing was not associated with the LFO and am not using MIDI on it. It disappears if I lower the cutoff frequency enough. If I open up the filter cutoff all the way, it really screeches.
I shut it down and am letting it sit for a while. The main box did not feel warm or anything. I'm totally bummed out.
Any ideas would be appreciated. Thanks!
Joe
nigeynige
Re: Voyager Distortion Issue
Post by nigeynige » Tue Dec 31, 2024 10:44 am
Joe, I found your Forum post. My Select Series started doing this weird distortion. It sounds like the VCA mod has been applied and at full rate. So strange. Any ideas if you managed to fix yours at all? Nige
jnastasi
Post by jnastasi » Tue Dec 31, 2024 11:25 am
Hi Nige,
Moog Music had me send in the analog board, which they tested and replaced. When I reinstalled it, the problem went away.
HTH,
Joe
