Dfam and drumbrute sync issue
Hey guys, relatively new to this whole world. Can I sync a dfam to an arturia drumbrute? Trying different things and can’t figure it out. Can anyone tell me how?
- conspiracytherapist
Re: Dfam and drumbrute sync issue
Have you tried a cable from the Drumbrute's CLOCK OUT to the DFAM's ADV/CLOCK? As the manual describes, once you've connected the cables you need to hit RUN/STOP on the DFAM and then hit play on your Drumbrute's sequence. That should keep 'em in sync! ...and the DFAM will start and stop with your Drumbrute.
(Tip: ADVANCE the sequence on your DFAM to step 8 so it will start it's sequence on step 1 once you hit play on the Drumbrute.)
Moogs: Voyager, Sub Phatty, Mother-32, DFAM, MF103 Phaser, MF104M Delay, MF105M MuRF, MF107 FreqBox, MF108M Cluster Flux
Music: http://soundcloud.com/conspiracytherapist
Computer: MacBook Pro, Ableton Live 9 + Push 1
