Moog Prodigy keyboard issue
philip_morison
Post by philip_morison » Sat Feb 10, 2018 3:03 pm
When I go between the from any note higher than the middle F to the middle F itself the pitch does not changes, it glitches . When I play the middle F key on its own there is no problem with the sound . Its only when I transition, none of the other notes have this problem. Obviously you cannot from a low note to a high note due to the monophonic nature, but you can go from high to low. Would anyone know where this problem could arise from. I feel that its fixable and every other part of the synth works perfect with no problem.
thealien666
Re: Moog Prodigy keyboard issue
Post by thealien666 » Sun Feb 11, 2018 11:58 pm
I would start by carefully cleaning the keyboard contacts and buss bars.
Here's a short video showing one method of doing it.
https://www.youtube.com/watch?v=Y7X6iMvhKEA
markcowell23
Post by markcowell23 » Fri Aug 23, 2019 3:19 am
thealien666 wrote:I would start by carefully cleaning the keyboard contacts and buss barsbestwashingmachine.in Here's a short video showing one method of doing it. https :// youtube .com/watch?v=Y7X6iMvhKEA
The video is not opening
till
Post by till » Fri Aug 23, 2019 8:24 am
Video plays fine here.
