I'm wondering which volume pedals would work best with Werkstatt?
I'm running my werkstatt to a delay pedal and then to a loop pedal and then to the PA.
Any suggestions?
High or low Impedence volume pedal
Re: High or low Impedence volume pedal
I was thinking along the lines of differences in impedance between different volume pedals.
Will this effect the sound?
I am basically looking for a clean volume fade for the recorded loops and possibly the same for the werkstatt sounds - altough a volume pedal that effects the tone could be considered in this case.
All suggestions are appretiated.
- _DemonDan_
Hi katainsun,kaptainsun wrote:I'm wondering which volume pedals would work best with Werkstatt?
As a rule, you want to use high-impedence pedals for things like passive guitar/bass pickups, and low-impedence pedals for things that have line-level outputs.
So, the low-impedence is best for the Werkstatt, but you could get away with using a high-impedence volume pedal if you needed to. (It's using a low-impedence volume pedal on guitar that would cause more problems.)
Here's a video I made discussing high/low-impedence volume pedals vs. continuous footcontroller pedals:
https://www.youtube.com/watch?v=fcc8scMQIrE
_
_DemonDan_
_
