I made a little video showing how you can pair with the MF-108M with a semi-modular synth and modulate some of its parameters via CV control.
https://youtu.be/ecuxv9FzeVo
[VIDEO] MF-108M + Roland Model 101
Re: [VIDEO] MF-108M + Roland Model 101
There is definitely a lack of good vids about MF-108. Thank you!
Some Records
mf(101+102+103+107+251)+some other gear
There is also a lack of good videos on here, thank you for adding to the databasebloodsample wrote:I made a little video showing how you can pair with the MF-108M with a semi-modular synth and modulate some of its parameters via CV control.
- _DemonDan_
This video is over 6 years old, but it does cover many of the MIDI Commands and Control Voltage possibilities:kxx303 wrote:There is definitely a lack of good vids about MF-108.
https://www.youtube.com/watch?v=3CpkKZDWeXQ
_
_DemonDan_
_
I've watched this one for so many times! Fantastic demo! Especially that moment when Cluster kicks in for the very first time, widening the stereo field. Breathtaking._DemonDan_ wrote:This video is over 6 years old, but it does cover many of the MIDI Commands and Control Voltage possibilities:kxx303 wrote:There is definitely a lack of good vids about MF-108.
Thank you, Dan
Some Records
Thank you Bloodsample for a simple and elegant video. Your explanations vs. playing ratio is spot on. I knew all this stuff anyway, yet it makes a difference in my mind when I see it demonstrated.
Stephen
Stephen
