Minitaur editor - new features missing
Hi everyone - I updated both my Minitaur and the editor to the latest versions, but the editor seems to be missing some of the new features (filter EG delay/hold time, amp EG hold time and drone). Have I messed something up, am I using the wrong version of the editor, or are those features simply not editable from the editor?
Re: Minitaur editor - new features missing
This is a copy of a reply I left on a similar thread, very apt to use it here:
Hope this helps.
The combination for the drone is: Glide + Sustain sweep from zero to fully openThe addendum (2.2) to the manual that ships with the new update illustrates a bunch of key combination/shortcuts which use the "Glide" key in tandem with EG Decay, VCO Freq, LFO rate and more to access a lot of Minitaur's hidden features directly from the hardware interface.
Hope this helps.
Strictly no bubblegum: Moog Minitaur, MF102, CP-251, EP-3, Komplete Kontrol S25, Maschine Jam, GAP PreQ-73, GAP Comp-54 MKII, TC Electronic Flashback Triple Delay, Spark, Dark Matter.
I made a cheat sheet for the Minitaur v2.2.0 firmware under-the-hood shortcuts. I taped it under the Minitaur for quick reference.
Note: the v2.1.0 states holding Glide and turning the filter knob changes triggering modes, this is also the same key combo in v2.2.0 for filter Envelope delay.
Yes, those features are available only on the hardware, not yet on this version of the Editor
http://audiotecna.info
Can the editor also be used for the t3 or still not ?
