![Very Happy :D](./images/smilies/icon_biggrin.gif)
The Programmable Shaping Offsets do not seem to do anything.
I've tried many combinations of programmable shaping inputs with various Source and Destinations on both the Pedal and Mod Wheel Bus.
The shaping inputs (both programmable and fixed) work - its just the offset (both High and Low) makes absolutely no difference.
I varied both High and Low from -64 to +64 while exercising the shaping input
I've also varied the bus amounts knowing that there's a maximum. Per the manual the offset varies the level between -2.5V and +2.5 V.
I'm also aware that the 2 bus shaping inputs get summed together
I know this has been posted about before but not sure if this is the same issue. I consider myself pretty good with this stuff and maybe there's something wrong with my Voyager? I'm also far from infallible. Anyway would appreciate if someone with OS3.6 could confirm or prove me wrong.
