Minimoog Model D Rogue Screw
Hi, I received a Minimoog Model about two weeks ago and have been blissfullly playing away on this thing for hours. I have a small problem with it though. It came with a rogue screw in it! I checked all the holes and they are all filled with screws, so this must have been one that just got left in it. The reason I know it's a screw is, it sticks out of the very back bottom corner of the back panel, stuck at the screw head (just wanting to be let free). I tried calling Moog and left a message and alas, not an answer back. I am determined to not have to send this thing back to Zzounds. Does anyone know if I can just take the back panel off (some twenty screws!) and let that thing out? Damn you Moog!
Re: Minimoog Model D Rogue Screw
It is very easy to undo all the screws of the metal back and to open the panel's back. But depending where the screw sticks, it might be hidden behind some boards.
(my 2017 Minimoog opened)
Yeah, thanks. I was able to successfully get that thing out.
often when theres a screw floating around inside any unit (cassette deck, cd player etc) its one that was holding something and became dislodged.
Did you have a good look when it was open to see if there were any screw holes that were suspiciously empty?
