Using CV & Expression Pedal At The Same Time ?
didlisquat
Post by didlisquat » Sat Mar 04, 2017 11:20 am
I know that the Moogerfoogers don't allow for TRS and TS cables to be used at the same time. Is it the same or can the Minitaur use an expression pedal and be controlled with TS cables from the CP~251 at the same time ? I wanted to check before I tried it just in case it could harm the Minitaur somehow.
didlisquat
Re: Using CV & Expression Pedal At The Same Time ?
Post by didlisquat » Thu Mar 09, 2017 10:34 am
Just in case anyone else ever has this question :
The customer should have no problems using both the EP-3 and the CP-251 in conjunction with the Minitaur. Using TS and TRS cables in tandem shouldn’t pose any problems either, the EP-3 only requires the TRS cable for powering the pedal off of the buffered inputs on the Minitaur.
