I just unpacked my new Minimoog Model D reissue. What a wonderful instrument.
It will set next to my 1979 Minimoog I bought used over 30 years ago.
My question:
Where to find the sysex documentation?
I haven't found them on the Moog pages.
Minimoog reissue: Sysex documentation is where? -> found
Re: Minimoog reissue: Sysex documentation is where?
I found the SysEx documentation after registering my Minimoog.
You will see on the top left, once you logged in, SUPPORT. And its there under the DOWNLOADS menu item.
For SysEx freaks here some information found in the above SysEx docs (you need to know about hex numbers of cause):
By sending
as SysEx to the Minimoog, you will receive the firmware version in a response formed like this:
So the response
means version 1.8
By sending
Code: Select all
F0 04 15 7F 15 00 00 00 F7
Code: Select all
F0 7E 7F 06 02 04 00 15 00 01 00 00 [v_min] [v_maj] F7
Code: Select all
F0 7E 7F 06 02 04 00 15 00 01 00 00 08 01 F7
Re: Minimoog reissue: Sysex documentation is where? -> found
The SysEx Data Sheet PDF is also available from the downloads tab on the Moog Model D product page: https://www.moogmusic.com/products/mini ... nloads-tab
