So, I was about 10 minutes from pulling the trigger on a used Voyager Electric Blue with a VX 351 included at Guitarget (Guitar Center). Everything felt and sounded pretty good, BUT, as long as the DB25 -> VX 351 were hooked up, the LFO would start to misbehave.
Without the VX 351, LFO light would pulse at it's programmed pace for all patches and the mod wheel behaved as expected. Connected, the LFO light pulses until you touch a key, then it STOPS. If you stop playing eventually in some cases the LFO would start to pulse again.
Here's where is gets extra-weird...If you plug a cable into the triangle wave patch point, the LFO would pulse normally again and the mod wheel would work, BUT the LFO would pulse at a DIFFERENT rate and the pulse light would blink more strongly (darker lows, brighter highs).
Is this normal or should I RUN AWAY?
Thanks for your help!
Electric Blue + CV Expander Kills LFO?
Sub 37 (Oct, 2015 Build) + Model 15 (app)
DSI Tetra, K2500RS, Juno 106, SH-32, JP-08, CS6x, Logic/RME Babyface
Re: Electric Blue + CV Expander Kills LFO?
This ended up being one of the units with the "Wrong Chip". It eventually led the the synth just dying. Sent it back to Guitarget.
Feel for you, I had my fingers burned the same way. I now have a spare board with a dead oscillator for my old school. the new Minimoog with a PSU is on sale now. Err no thanks.
You should speak to Moog's tech support. Include the S/N of your EB. There is a chance your unit qualifies for an extended warranty.rpernett wrote:This ended up being one of the units with the "Wrong Chip". It eventually led the the synth just dying. Sent it back to Guitarget.
If if does, they will replace you the faulty board for a new one at no cost
http://audiotecna.info
