Can't get anything but last note priority to work.
Everything Sub.
Shenes
Post by Shenes » Mon Feb 06, 2017 5:45 pm
After updating my sub 37 to FW 1.2.0 I can't get the keyboard priority settings to work properly. The only thing that works as before is LAST. Both LOW and HIGH gives the the same result, a sort of "inverted" LAST. LOW and HIGH holds on to the first note, even if I play many and only after i release any of the held notes the new note plays.
This is true to all patches and using the global KB priority or per preset gives the same result.
Really weird, anyone else? Am I doing something wrong?
best regards,
Johannes
Sander37
Re: Can't get anything but last note priority to work.
Post by Sander37 » Sun Feb 12, 2017 11:22 am
Confirmed.
I mostly use LAST so I didn't notice it earlier, but indeed, LAST seems to be the only mode that is working properly.
bichuelo
Post by bichuelo » Mon Feb 13, 2017 2:36 pm
Sander37 wrote:Confirmed.
Confirmed, as stated above
http://audiotecna.info
bichuelo
Post by bichuelo » Mon Feb 13, 2017 3:05 pm
Moog's tech team is aware of this issue, it has been reported already.
They don't have a date for when it would be fixed but it will, for sure, be addressed in the next firmware version
