Editing control parameters
Everything Sub.
jonboy3650
Post by jonboy3650 » Sat Feb 04, 2017 10:23 am
I have searched for this but somehow can't find an answer.
I can set the pgm source and pgm destination for a modulator via the front panel. But can I do this through the software editor?
If I can, I am clearly asking the wrong question or asking it the wrong way. If I can't, it seems strange, as that has to be a really useful creative device.
Any help?
jonboy3650
Re: Editing control parameters
Post by jonboy3650 » Sat Feb 04, 2017 10:29 am
Ah! I think I just found it - under the LFO section of the 'editor' tab in the editor. Cool.
Probably should read the manual ...
I'll leave this here so someone else might find it if they need to.
breun
Post by breun » Sat Feb 04, 2017 10:33 am
Assuming you are referring to the Sub 37 editor: the PGM SRC and PGM DEST settings are in the extended parameters section of the editor. You can see them in on page 2 of the Sub 37 editor manual. As explained to page you can click the the grey triangle at the bottom to show/hide the extended parameters window.
