Mother 32 not receiving midi
Hi! I just bought an Mother 32 and i can't figure it out how to make it receive midi from my Komplete Kontrol S61. First thing i did was Midi OUT from Kontrol to Midi in Mother ( nothing happened ) , tryed to turn the keyboard in midi mode Shift + Instance, still no midi to the mother 32. I entered the software ( komplete kontrol ) Preferences - Midi - Devices - Output - checked the boxes that are there : Komplete Kontrol 1 ; Komplete Kontrol EXT 1; Komplete Kontrol DAW 1..still not sending midi to the mother. I'm missing something or my M32 is having a problem?
Re: Mother 32 not receiving midi
If you are using your KK with the USB cable plugged to your computer, you must route the MIDI signal in order to be sent through the physical port on the keyboard. You can use MIDI-OX, MIDI Patchbay, Logic, Ableton Live, Protools.
If you unplug the USB cable and use it without computer it will work directly
http://audiotecna.info
