Stand recommendations for Sub 37
Hi all.
I just got my Sub 37 a few days ago and I've been looking for a stand for it. There doesn't seem to be much out there. In fact, I haven't found anything I'd consider suitable.
What do you folks use to prop up this beautiful little synth?
Re: Stand recommendations for Sub 37
How do you play the synth live? Or is the stand for studio use?
I use an X stand on the highest setting when I only have my S37 for a gig and stand. If I am playing my Nord Stage at the same time, I put it on the same X stand with a second tier that holds it pretty well. At home I built some shelves to house all the small synth stuff.
Just about any stand should work. What are reasons you don't consider a stand 'suitable'? Suitable for what exactly?
My Sub 37 just showed up, and I was just about to post the same question. I'm guessing your suitable request involves getting the right width (slim) without being too wobbly? I decided to jump the gun and get this.
https://www.amazon.com/Heavy-Keyboard-S ... B6AAJEW6ZF
The width looks kinda close, but the price is fantastic, and all the reviews say it's rock solid. I may have to remove the Sub's feet, or make a little wooden tray, We'll see soon!
My Sub 37 sits on a Quiklok T-22, because I wanted a compact stand for two synths. Works fine, compact for transportation (gigs).
I'm looking for a tilted keyboard stand like the one in his video :
https://www.youtube.com/watch?v=VxX5Mj9Fc8A&t=1646s
Good look at 6:52 and many other times.
Anybody ?
Or no one knows ?
Anybody ?
Or no one knows ?
That looks like a second tier on a "X" stand but just used from the other side, so the keyboard tilts away from her instead of towards her.Tsaddeous wrote:I'm looking for a tilted keyboard stand like the one in his video :
Thanks for the responses folks. Blown away by how helpful you've been.
Ideally what I want is a Z-style stand (for stability) but made especially for smaller synths like the 37 / Phatty. I'm amazed that such a thing doesn't seem to exist.
It's purely for studio use.ebowen4221 wrote:How do you play the synth live? Or is the stand for studio use?
I think most stands are too wide. For example, I have a Roland KS-18Z for my JD-XA. I've tried my Sub 37 on it and it's too narrow. One bump and the Sub will fall through the middle.breun wrote:Just about any stand should work. What are reasons you don't consider a stand 'suitable'? Suitable for what exactly?
Your right, most are for larger synths. This one seems to be the best fit for a Z stand...
http://www.musiciansfriend.com/accessor ... oard-stand
But I cheaped out and risked going with the slight wider, but much cheaper Z stand I posted above. Here it is.
Only half the price, andt more heavy duty, but 1" wider, which get kinda iffy. I could tell you more in a week.
I went with the Proline branded version of the Onstage Z stand, and it works great with the Sub 37. I use it as it's narrowest setting, and it is then nearly six inches narrower than the synth. In this configuration, it is very stable. I also got the second tier which I use for either the Slim Phatty or Minilogue.
Ive been using the strukture stands, B@h used to carry them but not anymore, super sturdy and they make a few versions..
http://strukturegear.com/product/297/SK2X-WT
- _DemonDan_
Hi aled,aled wrote:I just got my Sub 37 a few days ago and I've been looking for a stand for it.
While Z stands are certainly sturdy, I always find my legs hitting the middle bar when sitting down.
When standing up, the Z stands won't get tall enough for me (I'm 6' 2".)
I've used both of these stands for my Little Phatty, Sub 37, and the new minimoog Model D.
http://www.sweetwater.com/store/detail/PlatformStdF
(up to 44" or 111.8cm)
(up to 43.5" or 110.5cm)
Stylistically, I like them because their width can be compressed so that the legs seem to exactly come from the corners of whatever keyboard you put on them. It's a very clean look; and nothing gets in the way of your pedals (even organ pedals).
Ergonomically, I like them because, at 6' 2", I can stand up tall and play.
_
_DemonDan_
_
I think this is exactly what I've been looking for. Thank you!kylverstone wrote:I went with the Proline branded version of the Onstage Z stand, and it works great with the Sub 37. I use it as it's narrowest setting, and it is then nearly six inches narrower than the synth. In this configuration, it is very stable. I also got the second tier which I use for either the Slim Phatty or Minilogue.
Hmmm. I hadn't considered a table-like stand before. Your point about the legs looking like they come from the corners of the keyboard appeals to me a lot._DemonDan_ wrote:Hi aled,aled wrote:I just got my Sub 37 a few days ago and I've been looking for a stand for it.
Might need to give them a go. Thanks for the links!
I'm a big fan of Quiklok stands (http://www.quiklok.com/).
I'm reorganising/downsizing my personal studio space and redecorating, so stuff is all over the place with my Sub-37 currently sitting on an 'Addis Cirrus' Ironing Board - it's a bit wobbly for fast passages and I need to take it off when I need to iron my shirts.
