Share/dump sequences between multiple Mother 32s?
Is there any way to transfer the sequences from one Mother 32 to another? I'm looking to perform a piece of music that will involve 3 Mother 32s, all with the same set of sequences, but each Mother 32 will not be playing the same sequence as the others at the same time. I would rather not have to program the same 50+ sequences on three different devices, and I don't want to use an external device for sequencing, i.e. a computer if I don't have to.
- _DemonDan_
Re: Share/dump sequences between multiple Mother 32s?
Hi the83,
I know you don't want to use a computer when actually performing, but at least consider using a computer sequencer to store the notes of your Patterns.
Just make sure the notes have spaces in between them (except for ones you want to Tie).
You could designate a super-low note (like C-1) to indicate that you want to swap in a Rest at that Step.
If you play those notes back into a blank Pattern while in Record mode, you'll at least save yourself the time it would have taken to input them manually.
_
_DemonDan_
_
