Post
by latigid on » Sun Sep 18, 2016 4:43 am
As far as I can make out, the Freqbox incorporates a few different modules: a VCO, an envelope follower, a VCA (normally connected to the envelope) and a PLL (phase-locked loop).
When "sync" is on (somewhat of a misnomer) the PLL will attempt to compare the frequency of the source input and use that to control the pitch of the VCO. For "best" results, the initial VCO frequency should be higher than the source or increased using the env. amount [to VCO] control.
It's the VCO which is affected, not the "incoming note." DSP pitch shifters work on a principle of sampling audio, deriving the pitch, applying shift, then finally digital to analogue conversion.
Hope that helps.
