Moog Families of Sound
- Chimponaut
What is the Mother 32 based on as far as the basic sound. (Not features) Does it fall into the Sub Synth Category...Sub Phatty, Sub 37 etc. Or is it based on the Modulars family sound? Moog call it a "Semi-Modular" so I thought it might be based on the modular's basic sound generation. (Same Oscillators) Same question for the Minitaur. If you had to put them into a Moog family how would you place them? Again, just the basic sound of the oscillators, not the features.
Thanks.
Thanks.
<> RME Raydat
SW: Nuendo
<> RME Raydat
SW: Nuendo
Re: Moog Families of Sound
I believe it's from the Werkstatt.
N.
N.
Minitaur belongs to the Taurus line.
I have both the Mother-32 and the Werkstatt and I feel a very different color in their overall sound...
http://audiotecna.info
- noddyspuncture
Somehow I very much doubt it...Chimponaut wrote: Moog call it a "Semi-Modular" so I thought it might be based on the modular's basic sound generation. (Same Oscillators)
Tom
I played both the Moog 15 modular and the Mother-32 at this past NAMM. The M32 doesn't sound at all like the modular. It is termed a "semi-modular" because of its patching system.Chimponaut wrote:Moog call it a "Semi-Modular" so I thought it might be based on the modular's basic sound generation.
- Chimponaut
Thanks all. This clears things up for me, sort of.
<> RME Raydat
SW: Nuendo
<> RME Raydat
SW: Nuendo
Looking at the oscillator board of a modular Moog, and a Werkstatt board..you can see the different technology at work.
N.
N.
Someone said elsewhere in the net that the Voyager is not part of the same family of the Model D, but of the Multimoog and Micromoog, based on the sound and not the circuits, from what I guess. Does this make sense?
And I beleive the Model D does make part of the modular family?
I don't agree. I used to own a Micromoog. It was a good bass and FX synth but its filter was too polite and its resonance a bit sterile. A Voyager on one oscillator still blows it away on leads.bichuelo wrote:Someone said elsewhere in the net that the Voyager is not part of the same family of the Model D, but of the Multimoog and Micromoog, based on the sound and not the circuits, from what I guess. Does this make sense?
People make erroneous comparisons between their Minimoog and Voyager. Almost every 70s-80s era production Minimoog had matched transistor pairs in the top and bottom of the ladder filter, which will cause the sound of Minimoogs to vary from unit to unit. The acid test is the filter resonance. The first few hundred Minimoogs had every transistor pair matched in the ladder filter, which resulted in better control of resonance. I have one of the first fifty, a RAM unit. And a Voyager. I have played two other RAM units and they sounded identical to my unit, yet every late Minimoog sounded different. Because my Voyager also uses all matched transistor pairs in the ladder filter, it sounds like my RAM unit. So I'm of the opinion that the Voyager does fit in the Minimoog class.
Since the model A and B prototypes used circuit boards from the modular and the production Minimoog circuits were derived from the modular, this would be true.And I beleive the Model D does make part of the modular family?
