Working away from a computer and tweaking the Hidden menu does not allow for a visual on whats activated.
I believe I've tweaked myself into no sound when Active Panel is engaged . Is there a Hidden Function reset back to zero sequence?
hidden functions reset on Sub Phatty?
- _DemonDan_
Re: hidden functions reset on Sub Phatty?
Hi misfitit,
Here are three Sub Phatty Resets:
First engage Shift mode by holding down the BANK 4 button and pressing the ACTIVATE PANEL button.
INITIALIZE PRESET
Engage Shift mode and press BANK 3, BANK 4, and PATCH 1. Press C# twice to reset all the Shift-mode parameters to their default settings.
INITIALIZE GLOBAL PARAMETERS
Engage Shift mode and press BANK 3, BANK 4, and PATCH 2. Press C# twice to reset the global parameters (Local Control, MIDI Output Filter, Use Preset Volume, Use Preset MOD Wheel, Note Priority, Knob Wheel) to their default setting.
RESTORE FACTORY PRESETS
Engage Shift mode and press BANK 3, BANK 4, and PATCH 3. Press C# twice to reload the Sub Phatty’s 16 factory presets.
NOTE: Invoking this command will delete any user presets.
INITIALIZE PRESET
_
_DemonDan_
_
