I was looking at the table of parameters in the Sub37 manual, and noticed that the NRPN table has nothing for the amplitude envelope. So, I went digging a little and came up with this. The zip file contains some CSV and PDF files.
The three CSV files contain the same data but sorted by parameter name, CC number, and NRPN number. The CC table is also truncated to show only the parameters controlled by CCs. There are also PDFs from each of the CSVs formatted for US letter and A4 sheets.
Sub37: Parameter list with CC and NRPNs
MBP 2012 | OS X 10.11.6 | Sub 37 #6768
Re: Sub37: Parameter list with CC and NRPNs
Thank you!
Champ!! Finally all in one place. Thanks.
Thanks for your work!
Fantastic work, thank you!!
http://audiotecna.info
