104M Midi Note mode
Dapifer
104M Midi Note mode
Post by Dapifer » Mon Aug 29, 2016 4:05 pm
Has anyone made use of this? I want to check I'm understanding it right. I love the glitchy sound of changing the delay time while in Midi sync mode, does Midi note mode mean I can play these delay times using a midi keyboard? If so, I can't seem to get it to work.
Use the Sub 37, turn the panel midi on and press the corresponding button on the panel for the correct midi value to be sent to the Moogerfooger. Then when I hit the keyboard notes 0-90 (with keys midi mode on), I don't hear any changes in the delay time.
Am I misunderstanding this completely? Also does this mean you can send notes from the midi sequencer to change the delay time in sync?
*Edit* Just realised that it works but only when midi sync mode is off.
