Sub37 Editor and iConnectmidi4+ Problem
Everything Sub.
ChiLam
Post by ChiLam » Thu Jun 09, 2016 10:30 am
Has anyone managed to get the editor to connect to their Sub37 when the Sub is connected to an iConnectMidi4+?
For me the Sub37 is not visible to the editor this way.
delmarh
Re: Sub37 Editor and iConnectmidi4+ Problem
Post by delmarh » Thu Jun 09, 2016 4:12 pm
I have both of those devices but have yet to connect them together since I work out of town during the week. I know that the iConnect has LOTS of configurations and can be overwhelming at times. I'll give it a go this weekend and post my results to this thread.
I assume your path is as follows:
Sub37 USB -> iConnectMIDI4+ <- Mac or PC USB
If you are using the MIDI DIN connections to/from Sub37 and iConnect, let me know so I can test the exact connections you are using.
Also, what OS are you running on the computer hosting the Sub37 Editor? OS version?
ChiLam
Post by ChiLam » Thu Jun 09, 2016 6:03 pm
Hi delmarh,
I'm very interested to hear how it goes for you.
I use Windows XP 32bit on a PC and my Sub is connected to the iConnectMidi4+ by USB and by DIN. I had to disconnect the Sub from the ICM4 and plug it direct into the PC to install the new driver - it won't proceed until the Sub is visible. After installing I reconnected to the ICM4 but the VST couldn't find the Sub either.
I have just connected directly to the PC since and this works perfectly - just a shame the ICM4+ cannot pass through the devices which are connected to it so the host software can see it.
I wish you luck with your attempts :wink:
