Sub37 - sequence mod value waveforms
Everything Sub.
mikeh11
Post by mikeh11 » Wed Apr 20, 2016 4:18 pm
The attached zip file contains .seq files for the Sub 37 editor. The mod-values for the steps in the sequence define a waveshape. By using seq-mod-only you can play the mod-values only, and get sort-of a third LFO (with 64 steps per cycle).
Not for the faint of heart, I suppose! :-)
SeqModWaves.zip
Sequencer mod-value waveshapes
(46.9 KiB) Downloaded 119 times
MBP 2012 | OS X 10.11.6 | Sub 37 #6768
ObtuseMoose
Re: Sub37 - sequence mod value waveforms
Post by ObtuseMoose » Thu Apr 21, 2016 10:55 am
Nice! I wish the glide function would work on sequencer mod values.
Moose
bernard
Post by bernard » Thu Apr 21, 2016 12:35 pm
Thanks mikeh!
What an effort!
The disadvantage is, if you record a new sequence (for using it together with the modulation), all the modulation values are set to 0.
You write in your readme : "...since the sequencer does not have a modulation destination for the oscillators".
Osc 1+2 level can be modulated, Osc 2 frequency also, however the range is limited to +/- 7 semitones of course.
Osc Octave can also be modulated for both oscillators, I wonder why not the waveform. Seems arbitrary.
A glide function, ObtuseMoose, would be great. I already suggested it in this thread I opened in the beta forum.
cheers,
Bernard
mikeh11
Post by mikeh11 » Thu Apr 21, 2016 6:44 pm
Good catch! I meant to say that we cannot change the pitch, but that's not what I wrote, eh? :)
I'll change it in case I ever update/repost.
And
Oh, sure! Already you want something to merge the modulation values with an existing sequence?
Hmm. Good idea! :)
And, yeah, the different collections of subsets of available modulation destinations is driving me batty. Maybe I'll make a chart and add it to that "other" doc....
