Sub Phatty Editor (x86) VSTs not showing up in Windows 7
Posted: Tue Jan 26, 2016 2:29 pm
I'm running Ableton Live 9.5 (32-bit) on Windows 7 (64-bit). I manually copied the 32-bit DLL files to my VST plugins directory but neither DLL is showing up in my plugins. I tried rescanning from within Ableton but still no luck. I have several other VST editors for other hardware synths, one of which required manually copying the DLL's also but I have never had this problem before.
I found another post from somebody with the same issue and they said renaming the DLL's filenames worked for him:
http://forum.moogmusic.com/viewtopic.php?f=7&t=24436
I tried his advice but it didn't work for me. He was using Ableton Live 9.5 also but he's using 64-bit, apparently the fix doesn't work with 32-bit.
