Sub 37 synced to logic x. Arpeggiator on. Arpeggiator latch on.
When holding down two or more keys with my fingers, the arp plays all notes. When I release fingers from keys, only one note is arpeggiated (lowest note pressed), even if latch is on. For several notes/keys to be arpeggiated I have to hold down all the keys physically.
This is not the case when 37 is not connected/synced to DAW: When pressing down several keys and releasing them, the arp continues to arpeggiate all notes/keys that recently were pressed down.
Why is it not possible to release the keys when 37's connected to a DAW, with the arp continuing all notes?
Sub 37 Arpeggiator latch issue
MacbookPro 10.10.4 64 bit
Moog Sub 37
Motu Ultralite
Logic X / Live 9
Moog Sub 37
Motu Ultralite
Logic X / Live 9
Re: Sub 37 Arpeggiator latch issue
It's because the SEQ is send to the DAW and come back to the Sub37, triggering the same note again, and again ... it's like if you press the same key at the sequencer tempo.
You can switch this option to KEYS in the menu.
I'm used to switch local OFF and route the MIDI back to my Sub37 with my MIDI controller and got the same issue. it took me an hour to figure out
Sub 37 (FW 1.2.0 / 1.0.1), Minitaur (FW 2.2.2 / 3.3.0), MF-Drive & MF-Delay
Ableton Live 11 on macOS Big Sur v11.2.3
