hello,
when sub 37 is connected via usb to my iMac,sometimes the connection between the synth and the daw disappear,
i need to turn off and then on the synth to make it work...
if i disconnect the cable and reconnect it don't seem to restore the connection, the only way is to restart the machine..
anyone can help me?
thanks
SUb 37 MIDI usb Problem
Re: SUb 37 MIDI usb Problem
I get similar with Ableton (better since 9.5 tho) , often a note hangs then after reset (octave up & down buttons) there appears to be no connection with computer.
Turning sub 37 on and off doesentmake a difference or restarting ableton, Mac has to be restarted for Sub to be seen again.
Midi clock sync is wayyy off too , really erratic.
I had the same problem when I was using a usb hub - it went away with a direct connection to the iMac.
My Sub 37 Patches - Sub 37 + Mother 32 + UR-44 + OS X 10.11/Ableton Live/Logic Pro X + Push 2
