Sub 37 headphone jack crackling and distorted
Hi just got my sub 37, and once programing from an initial patch osc 2 became noisy and distorted although non was dialled in by me, has anyone else had this problem and should I be worried? So far it's not repeated it
This turns out to be the headphones out Jack becoming noisy and distorted (not lead related) sounds like the headphone amp not the pot
Any suggestions?
Any suggestions?
Re: Sub 37 headphone jack crackling and distorted
Hi there,
Andy from Moog Tech Support here!
Please contact us directly for assistance with this issue, we will be happy to help you get it sorted out.
Andy Hughes, Service Manager
andy@moogmusic.com
828-251-0090 xt 221
Nate Marino
natemarino@moogmusic.com
xt. 204
Taylor Mott
taylor@moogmusic.com
xt. 217
Thanks,
Andy Hughes
Service Manager
Moog Music, Inc.
andy@moogmusic.com
828-251-0090 xt 221
Nate Marino
xt. 204
Taylor Mott
xt. 217
Thanks,
Andy Hughes
Service Manager
Moog Music, Inc.
I have the same problem. Sound from Headphones out is noisy/distorted. Line out sounds fine.
Moog Sub37, Windows7 64, Cubase 8.5
Same here but it only happens occasionally, out of the blue (I rarely use the headphone socket so it would probably happen more if I did). Definitely sounds like an op-amp or something because it's random and maybe after pushing it a bit. If it was a wiring problem I'd suspect it to be more often and more likely to stop once it starts.
My main volume knob will also occasionally have some "oxidised" sounding bad contact at 12 o'clock and maybe 4 o'clock, then next time it's gone ( I thought the pot was bad previously but it comes and goes...)
I know we can contact Andy etc but if anyone else has had this and knows anything that it being a fault with the hardware please let us know as it would save time and lots of to/fro.
I also have this issue, headphone jack sound distorted _sometimes_ but not always. The cord and headphones are ok, check with several other instruments.
Seems to me like a crappy headphone amp in the sub37.
Hi does sound like an op amp issue to me. But Andy from moog suggested it sounds like a loose cable from headphone jack and the board.
Tell me what you think as mines in for repair and due to the intermittent nature of this issue will the engineer find the fault?
Well make sure to update us on what they say! The fact mine always happens after X amount of time (heat related perhaps) makes me feel it's not the wiring. I've repaired similar faults on old alpha juno op-amps, soldered in a new chip to get rid of crackling but something simpler like a lose cable would be better of course. I guess on the Sub 37 the op-amp chip is SMT which makes it trickier, though not impossible, for the DIY-er in years to come if they fail.
Looks like it's the headphone amp, they're going to replace the complete board, may take a couple of weeks as they have non in stock!
