Mp-201 lfo and expression modes
This is the place to share tips, tricks and questions about Moog's controller products; the MP-201 Multi-Pedal and the EP-2. There are a world of applications for these expression enhancers. Explore...
TimeEchoProductions
Post by TimeEchoProductions » Thu Oct 22, 2015 11:40 pm
Hi, I tried to search for this answer and couldn't find it.
I don't have the mp-201 but I have been keeping an eye out
For one if I can get a decent deal.
I want to know if the 4 channels can be doing different things
Such as having some do LFO while other channels are in expression pedal mode.
I got the impression from the manual that lfo mode makes all
Four channels lfos, I am hoping that is not true.
Thanks,
Tim
Voyager XL, Minitaur, MF-101, MF-102, MF-103,
MF-105m, MF-107, MF-108m, MP-201
Thomas Monticello 371 with Moog preset Synthesizer
stiiiiiiive
Re: Mp-201 lfo and expression modes
Post by stiiiiiiive » Fri Oct 23, 2015 2:37 am
Each channel can have a different function, or not. LFO, noise, expression, gate, envelope, MIDI-to-CV.
Basically, you can run the pedal in two modes.
In single mode, one channel at a time is controlled by the expression pedal and switches allow you to toggle on/off the current channel and switch channels.
In quad mode, each footswitch toggles on/off a channel (or trig a gate or envelope if in those modes), and the expression pedal can control either the four channels or the last that was switched on –this is a configuration parameter.
TimeEchoProductions
Post by TimeEchoProductions » Sat Oct 24, 2015 2:19 am
That's great. Thanks!
