Best stand for Sub37?
Hello I need to get a stand for the Sub37, just a single keyboard stand that is sturdy and looks decent.
I've spotted this Hercules one and heard good things on the Phatty forum from Sub Phatty users about the fit.
http://www.herculesstands.com/keyboards/KS400B.html#
Before I take the plunge I wanted to see if there are any alternatives I should consider?
Thanks guys....
Thanks guys....
Re: Best stand for Sub37?
They are good stands. I have used them in the past for 61 key kbrds. I imagine it should fit a Sub 37 just fine. I currently use this On Stage Stand: On-Stage Stands KS8290 Lok-Tight Pro Single-X ERGO-LOK
Howdy... I use a similar Z type stand: On Stage KS7350 Pro Heavy Duty Folding Z Keyboard Stand. It is extremely sturdy and is adjustable so the width fits inside the rubber feet of my sub 37. I would recommend this type of stand
The problem with most X stands is that they aren't narrow enough to hold a moog, at a seated height.
I ended up getting this one and it's been rock solid.
Stellar Labs 555-13830 Heavy Duty Keybo ... 7vbJNFX9BD
Moog Format Modular
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
A great point. I failed to mention that I only use the stand I recommended at gigs.jsharpphoto wrote:The problem with most X stands is that they aren't narrow enough to hold a moog, at a seated height.
I figured 98% of you guys play standing up, I just wanted to throw that out there in case there are any guys who sit, like me.
Moog Format Modular
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
I have both my Kronos and Sub 37 on Z stands. I play seated. I have never liked X stands - find they bounce too much. The Z stand I have for the Sub 37 is a permanent style Z that I got for about $50 - I think presonus, and it's solid a a rock.
I think the main questions are:
1) do you play standing or seated? (If I was standing, I'd go spider)
2) do you have to break down the gear to gig, or is it relatively permanent? (Breakdown, I'd go hercules Z)
3) do you need tiers? (spider again)
4) How much will you spend? (At some price point, it is better to go modular)
- Rufus the Dog
Thanks for the tips, chaps... have a Hercules KS400B on its way
R.
R.
Good points.....Ottawa58 wrote:I have both my Kronos and Sub 37 on Z stands. I play seated. I have never liked X stands - find they bounce too much. The Z stand I have for the Sub 37 is a permanent style Z that I got for about $50 - I think presonus, and it's solid a a rock.
I play seated, its never used to gig, I don't need tiers as its my only synth, nothing too pricey but good quality within reason... (what are modular options?)
Many thanks for all the suggestions everybody...
if you play seated, at home, get the one I sent. It's rock solid, and $40Tonejammer wrote:Good points.....Ottawa58 wrote:I have both my Kronos and Sub 37 on Z stands. I play seated. I have never liked X stands - find they bounce too much. The Z stand I have for the Sub 37 is a permanent style Z that I got for about $50 - I think presonus, and it's solid a a rock.
Moog Format Modular
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
Model D (2016)
Moog Subsequent37
Oberheim OB-6
Sequential Rev2
Yes the Stellar Labs one looks great & really solid - just one hitch - I can't find it in the UK....
PS It really does look rock solid with the triangular construction - everything else looks rattly by comparison!jsharpphoto wrote:
By modular, I meant the kind (like Gibraltar) where you build your own configuration out of their tubes, and various connectors. You order the pieces you need and they all go together. Not at all portable and a bit expensive. Popular amongst drummers, but you can usually order keyboard configurations too. I thought about doing it, but my Hercules Z is fine considering price.
http://www.gibraltarhardware.com/?fa=workhorse
- Bald Eagle
Those Gibraltar components look interesting. I've been looking for a dual tier stand for my Sub 37 and Sub P that will fit in the corner. Building my own may be the best way to go.
I bought a Gator Frameworks heavy duty table stand for sitting at. Then I build a custom shelf to sit on top which houses the Sub 37 which has an angled top shelf above to hold pedals and drum machine. Really nice having the other gear close by but it's a studio only setup.
