Hi
I'm pretty new to my Sub 37 and this forum. I'm having trouble figuring out how to record modulations into the sequencer. If someone could help with the setup of a basic function like filter cutoff I would really appreciate it.
I'm using the new 1.1 update.
Thanks!!!
SEQ MOD Help
Re: SEQ MOD Help
Ok so I managed to record modulation into the sequencer using MOD DST in the Preset/Sequencer menu. I'm still not able to do it via the two Mod busses. Has anyone successfully done this yet?
- _DemonDan_
Re: SEQ MOD Help
Hi tsv,
If you have a SEQ recorded with Sequence Modulation (i.e. you moved the Mod Wheel to different locations at each step of recording), you can then use this as a Modulation Source in both MOD 1 and MOD 2.
Just set the MOD SOURCE knob to PGM, press CONTROLLERS, go to PGM SRC and set it to SEQ MOD.
Now, turn that MOD's FILTER AMT (for example) to some non-zero value.
Set the FILTER CUTOFF knob to somewhere in the middle.
Turn RESONANCE up (to make it obvious), et voila!
_
_DemonDan_
_
Re: SEQ MOD Help
Thank you!!!!
Thant works great!
Thant works great!
