minimoog D noise on filter?
ClockworkRobot
Post by ClockworkRobot » Thu Apr 30, 2015 10:52 am
Quick question.. Should i be able to hear white noise on filter modulation with noise switched off? got a Model D. Definitely hearing a white noise hiss on the filter and the only way i can get rid of it it to hang the noise switch in a position between white and pink.. that can't be right, can it?
Thanks.
MC
Re: minimoog D noise on filter?
Post by MC » Thu Apr 30, 2015 12:45 pm
Sounds like your noise switch is... noisy
megavoice
Post by megavoice » Thu Apr 30, 2015 1:23 pm
ClockworkRobot wrote:Quick question.. Should i be able to hear white noise on filter modulation with noise switched off? got a Model D. Definitely hearing a white noise hiss on the filter and the only way i can get rid of it it to hang the noise switch in a position between white and pink.. that can't be right, can it?
Thanks.
No, that`s not o.k.
If "Noise" is completely turned off, you shouldn`t hear any noise in no way anywhere.
MC will be right, very likely.
"Losers always whine about their best. Winners go home and fu** the prom queen." —Sean Connery to Nicholas Cage in "The Rock" (1996)
I've never seen any real prom queen here in my country, but if we had some they'd
**** with everyone.
