I noticed the "Out Vol" destination controller is missing from the Controllers Menu: PGM DEST. Is this a future implementation? I thought it would be interesting to use keyboard velocity sensitivity to control this destination. I have 1.0.7 installed, which currently is the latest firmware.
Gary V
Sub 37 Master Volume Level Controller Destination
- _DemonDan_
Re: Sub 37 Master Volume Level Controller Destination
Hi Gary,garyv wrote:I noticed the "Out Vol" destination controller is missing from the Controllers Menu: PGM DEST. Is this a future implementation? I thought it would be interesting to use keyboard velocity sensitivity to control this destination.
The best way to modulate Amplitude with Velocity is via the AMP ENV's VEL AMT parameter.
Press the KNOB SHIFT button between the two EGs and then use the AMP EG's SUSTAIN knob to set it.
Remember that it works negatively:
The more you turn it clockwise, the quieter your low velocities get.
Don't forget to immediately turn off the KNOB SHIFT button or you'll screw everything up when you try to adjust EG times later.
_
_DemonDan_
_
Thanks DemonDan, I'll give that a try.
I was afraid the "Out Vol" destination wouldn't behave as I wanted, perhaps that's why it's apparently not yet implemented on the Sub 37. Thanks again.
Gary V
