swiss_destruction
Post
by swiss_destruction » Thu Feb 09, 2006 6:35 am
well i just thought that it would be nice if we all share our insight on moogerfiguration so...just write down what parameters and cv patches and what moogs you use
for now i only use the phaser and the lowpass but still i can get some neet stuff from self oscillation and combinning some cv's and also by hooking up an instrument....this month i'm gonna get the cp251
and get a bit crazy with it...anyway i'm not home so i can't check my "patch notation book" so when i'l get home i'l post something
today's sh@it is the manure for tomorrow's roses
GregAE
Post
by GregAE » Thu Feb 09, 2006 10:04 am
swiss_destruction wrote:well i just thought that it would be nice if we all share our insight on moogerfiguration so...just write down what parameters and cv patches and what moogs you use
I'd be interested to see how you notate these patches. I don't think I've seen a truely good method yet.
- Greg
Impossible Sound
Post
by Impossible Sound » Thu Feb 09, 2006 12:12 pm
Patch diagrams can get messy and confusing. The simple ones like in the Mooger Manuals are ok, but things can get real complicated when dealing with a modular synth.
I usually make a list of each knob position and what each jack is connected to.
analoghaze
Post
by analoghaze » Sat Feb 11, 2006 12:20 am
I just wired up something a bit different from what I've done before.
It involves a Moog delay and a MuRF.
Loop Out of the delay into the MuRF.
One of the outputs of the MuRF into the Loop In.
The other MuRF output is wired into the Input on the delay.
This gives me the 2 audio outputs of the delay to process.
In all reality though, I have not worked with this set-up a whole lot, and this idea is quite simple, but it did spawn a new idea that will be wired up soon.
peter ripa
Post
by peter ripa » Sat Feb 11, 2006 12:23 pm
thats my favourite murf patching too
edit: no i only use one loop ie murf in between repeats
www.peterripa.com
http://www.peterripa.com/cgi-bin/index.cgi?action=musik
wademalorgan
Post
by wademalorgan » Mon Mar 20, 2006 11:33 am
I'm sure a lot of you have tried this but it sounds so weird I just had to post:
I've been messing around with my guitar, the 101, 104z and a cp251 and got this crazy warble-like sound using the envelope out of the low pass into the delay time input of the 104z. The key is to set your delay mix to 10 and your delay time to 0. Now you are only hearing your delayed, time modulated signal. Very cool pitch shifting. This effect is great but not too subtle. To tame it, I simply lower the voltage of the envelope follower. Instead of patching directly from the lowpass env. out to the delay time in, I patch the envelope to an attenuator on the cp251 and then out to the delay time. Keeping the attenuation very low (i'd say anywhere from 0 to 2). The note you play sounds like it begins a half to one whole step up then bends down to the original pitch as your envelope closes. Almost sounds like you're playing on a guitar that's been detuned 4 whole steps.
wademalorgan
