CP- 251 Four-way Mult Gate issues
masaski
Post by masaski » Fri Apr 03, 2015 12:59 pm
Hi there,
Just after a bit of assistance. Obviously you can send and redistribute a gate signal from the CP-251 four-way mult and I'm trying but nothing seems to be happening.
The source gate is coming from the Analog Four, and I'm running a couple of patch cables out of the mult to try and sync with another sequencer and a delay.
Any ideas as to why this isn't happening?
Cheers!
Mark
c7sus
Re: CP- 251 Four-way Mult Gate issues
Post by c7sus » Fri Apr 03, 2015 3:13 pm
Try it without using the red jack. Or white jack as the case may be.
masaski
Post by masaski » Fri Apr 03, 2015 5:45 pm
c7sus wrote:Try it without using the red jack. Or white jack as the case may be.
Hi, thanks for the reply.
The red/white jack on the CP251, or the CV lead itself?
c7sus
Post by c7sus » Fri Apr 03, 2015 6:07 pm
Well, my little theory appears to be incorrect. I was able to patch a gate off the Voyager keyboard through the mult with both TS and TRS cables. :oops:
What is the gate amount off the A4 and what are the other devices looking for in terms of a gate voltage?
You might try patching the gate off the A4 through the mixer section and use the offset to increase the gate voltage to the other devices via the mult if the gate off the A4 is less than what the other devices are looking for.
Marcie609
Post by Marcie609 » Mon Apr 06, 2015 8:49 pm
Works fine gate out of my Pulse 2 & Rhythm Wolf
Does a direct connection work?
Vsyevolod
Post by Vsyevolod » Tue Apr 07, 2015 5:07 pm
If you load up a multiple with too many cords, it may 'pull down' the gate to a low enough voltage that it no longer properly triggers other modules. It has to do with the interaction of the receiving modules and the difference between passive and/or buffered mults.
Start simple, put a gate in and take it back out of a mult. Then send the gate out to a second module and see if it still works. Then a third...
Stephen
masaski
Post by masaski » Wed Apr 08, 2015 7:07 am
Hi all, and thanks for your replies!
Could i experience any issues using a 'Y/Insert" cable into the mult? Because this is what i'm using coming from the 2 CV ports (ABCD) on the A4?
i recon'd my A4 to throw out the gate (A) first, then pitch (B), then the two 'value' controllers (C&D) and this seemed to work well. I juiced the power up on the gate into the mult to 10v and this is powering a filter seq and a delay.
Just wondering if there could be issues with using a Y cable into the CP?
Black-Man
Post by Black-Man » Sat May 23, 2015 11:43 am
Is the CP-251 mult buffered? These seems to be conflicting info on this.
