Sub 37, Can´t select letters with "fine tune"
Everything Sub.
TheFlowerKings
Post by TheFlowerKings » Mon Mar 23, 2015 1:54 pm
Hi List
I´m new here so sorry if this subject has been up before.
Yesterday everything worked perfectly but today when saving a sound I can´t use the "fine tune" knob to select characters.
Any ideas?
I have the Sub connected to DAW with local off (keyz)
Best
tomas
Beach Bum
Re: Sub 37, Can´t select letters with "fine tune"
Post by Beach Bum » Tue Mar 24, 2015 3:21 pm
Strange effect - same happens with mine :( And it worked in the beginning, too
GregVDS
Post by GregVDS » Wed Mar 25, 2015 9:27 am
You should report this as a bug to Amos at Moog (amos@moogmusic.com).
Don't forget to give your firmware version (numbers found at the bottom of the global settings), because maybe this is already fixed in the beta version of the next to come v1.1 firmware.
Greg
m10k
Post by m10k » Wed Mar 25, 2015 7:16 pm
Global menu--> Fine Tune --> Edit
Hopefully that will sort you out.
Beach Bum
Post by Beach Bum » Wed Mar 25, 2015 7:43 pm
m10k wrote:Global menu--> Fine Tune --> Edit
thx, will check this tomorrow!
Beach Bum
Post by Beach Bum » Sun Mar 29, 2015 4:02 pm
It did work out! No idea, why the settings in the menu changed, maybe I pushed too many buttons ...
If anyone else has this problem: You got two choices, tune and edit. In the tune mode you can - as expected - tune only. In the edit mode you can use the poti to edit (characters e.g.) and tune ... Nice!
GregVDS
Post by GregVDS » Mon Mar 30, 2015 4:17 am
Great news it's not a bug :-)!
