Club of the Knobs psu
rarecomponent
Post by rarecomponent » Sun Jan 18, 2015 11:41 am
No info anywhere, no reply from COTK....
I know my COTK 921is designed for a +/-12 v supply ...
Can it be safely run on +/- 15 v ?
Re: Club of the Knobs psu
Post by EricK » Sun Jan 18, 2015 12:12 pm
I asked him awhile back if his filter bank could run off a ddotcom power supply and he replied:
kazike wrote:yes!
USD 48.00
regards
/k
I also asked him if about his 960 several years ago and he mentioned it would ship with a dotcom connector.
So you probably need that converter, if you are handy with an iron you can build one much cheaper than that. I don't know if it can be "safely" run without the conversion, or if it would shorten the life of the components.
ualslosar
Post by ualslosar » Sun Jan 18, 2015 1:20 pm
Hi - Most COTK modules need a converter board to work with a Dotcom or MOTM power supply (+/-15V).
Hope this helps.
Larry
Rarecomponent1
Post by Rarecomponent1 » Sun Jan 18, 2015 4:28 pm
Thanks Eric....
I have one module each from .Com / COTK in my modular so now I have to have three PSU units in there ...
+ 12. -6. -10. Moog
+ 15 -15. .Com
+ 12. -12. COTK
and also + 5
So I was hoping to cut out the + - 12v
Actually their all becoming external seeing how the modular never goes anywhere.
JohnLRice
Post by JohnLRice » Mon Jan 19, 2015 4:29 am
A majority of the COTK Modules can run off of +-15v (I've run their LFO and a sequential switch off of +-15v even though they were setup for +-12v) but the VCO's are NOT able to do that. (I don't know it it would damage it or not to try but the main problem is they wont track correctly) At least that was the case a few years ago. For VCO's you'd need a step-down converter for the power and a connector converter. Maybe that's what the $48 was for, to ship one of their power converter strips?
FYI: Kazike of COTK is probably already on his way to the Winter NAMM convention in Anaheim CA USA so he may be hard to get a hold of for the next week or two.
John L Rice
Rarecomponent1
Post by Rarecomponent1 » Mon Jan 19, 2015 9:24 am
Thanks for all your help
I guess best stick to the 12 v supply rather than risk it with a costly module.
I need to organise my PSU collection.
