E.G.s - a problem with the attack / decay functions.
A Lyttle Folk
Post by A Lyttle Folk » Thu Oct 30, 2014 3:07 pm
Hello there,
I have a problem with my Voyager XL and it concerns the envelope generators.
The problem is, so far as I can tell, identical for both E.G.s but I’ll describe it for the volume E.G.
The attack knob makes no difference to the sound. The screen shows a changing value – so you still get the Memory / Actual values, with the “Actual” value changing as you move the control but the sound stays exactly the same.
The attack function is now transferred to the decay knob. So if you twist the decay knob you see the “Actual” value for the decay changing but the change in the sound is the attack – not the decay!
There is no decay function – that’s lost now. So the E.G. is, in effect, now Attack-Sustain-Release.
As I say, the filter envelope is exactly the same.
I have tried external gating, re-loading the factory date, resetting the pot mapping, envelope triggering – everything! I’ve re-loaded the operating system.
Nothing changes.
I know it seems like a user error or a software glitch, but having reset everything in sight and STILL having the problem I’m now thinking that it’s a hardware fault.
I’m sending this to Moog as well as posting it here but if anyone has come across this sort of thing before and / or got any suggestions of what might be wrong, please do let me know.
Many thanks for your attention.
hoobaprawn
Re: E.G.s - a problem with the attack / decay functions.
Post by hoobaprawn » Thu Jun 13, 2024 8:19 pm
Hello, 10 years later, did you ever discover the culprit behind this? I am having the EXACT issue with a standard voyager
Sickstems
Post by Sickstems » Fri Dec 06, 2024 1:59 pm
Hi There
Ive only just seen the posts regarding Minimoog Voyager Attack problems, Both attack knobs don't work at all and many other faults match the previous posts I've Seen, Please ! if anybody has any answers to resolve the problem or which chips are causing it, I would really like to hear from you
Hopefully talk soon
Pete
Sickstems Studios
RL
Post by RL » Tue Dec 10, 2024 6:55 pm
very often I got these broken TI chips in the ADSR circuits: U7/U29 (4052), U8/U30 (TL074), U44 (4013), U13 (LM339) or U28/U32 (4053). I guess one or more is/are broken.
http://www.moogmusic.de
