Just for sure. Sub Phatty have on the left side a mono OUT, right ? Not stereo OUT like headphone OUT on main panel ?
I'm asking because Im using mono jack to connect it to RME mono IN 3. Is that correct cable set ?
Thanks,
Pawel
Sub Phatty mono OUT, right ?
Re: Sub Phatty mono OUT, right ?
Yes mono out, a guitar cable should work fine.
http://audiotecna.info
Thanks you. Just as I connect it with guitar cable.
I wonder if RME FF400 IN 3 is good for analog instrument? Or should I connect it to IN 1 or 2 (these are with preamps and phantom option for mic)
The output is line level, you shouldn't need a preamp for that.
